Airflow System ASAC-5000 + NACA Vent Valve
Shays
Active Member
Hi Guys,
I am seeking help in understanding the option of combining the two systems with the Aerosport Overhead Console. I am using a builder assist so forgive my 3rd-grade technical knowledge.
Some questions:
Has anyone combined both Naca and Airflow System AC?
Are there any limitations I should be aware of?
Plumbing, is there a way it should be done vs a way it should not?
I am not sure if I am asking the right questions so if you have any input for me it would be much appreciated.
Thank you,
Thanks Rob, I did talk to Bill, he said it is doable but the condenser unit might need to change and some vent hoses modifications. He also mentioned that some builders did combine the two and that I might get some input here on how was it done and how it's been working for them.
Hi Shays,
It can be done a few different ways,
Mounting it on the back of the evap and plumbing to roof console via the evap manifold is the way I chose.
Once at altitude and a/c turned off, open Aerosport Valve for fresh air .
This install is over 5 years old now and I?m sure others have now done a better job. However ,click through the photo log in my signature for more info.
Cheers
