Airflow fuel injection control brackets
mhflyit
Active Member
My FWF kit has the bendix control brackets and I have the airflow fuel injection system which the brackets don't fit. Will new brackets need to be fabricated as airflow suggest or is there a source for these?
Best
Fab time. If somebody knows of a bracket kit for AFP on a horizontal sump, definitely lemme know!
FYI, I routed my throttle cable in from the left side:
Mixture, I came from the back and bolted to the bottom of the sump:
I ended up rotating the AFP servo 90 degrees to make all of this work. I know at least one builder here in SoCal who managed to make it work without doing that...throttle came in from back/under as well.
Use your imagination and any "bosses" on the sump you can. Let us know what you come up with.
As promised here are pictures of the control cable brackets and points of attachment for my engine/airframe combination.
Thx to those that helped me on this.
Best
