Foam-the-runway
Active Member
Are they the same tool from same manufacturer? Does any one know if there is a difference? Aircraft Spruce's is cheaper. Other then that the specs don't detail any major differences.
I'm also interested in which one did you use if you went that route. I see great reviews on the DRDT2 but I'm interested in C-frame information. Thanks in advance.
