Thanks for the input guys. Would you believe I completely forgot about the logbook that came from Rotax with the engine? Not sure I want to use it however, since its first language seems to be German - with English subtitles!
I have used the AdLog system with previous airplanes, but I think that is overkill for this one. Maybe I will just set up a loose leaf with sections, as suggested. Thanks again for the ideas.
