I would like to know if anyone knows of a source for the foam coupling between the air scoop on the bottom of the cowling and the air intake on the engine. I have a RV9A and a TMX IO320. Thank you.
If you are referring to the little foam block that Vans uses to make the intake layup to your airbox, Try a flower shop. They use this very same foam to make flower arraingements.
