From the picture is hard to see but the the left hand side air ramp is 1/2" higher than the bottom cowl. It's from Vans baffle kit and the air ramp is pre-drilled to the cylinder 2 baffle so it can't be a builder fabrication problem.
If I attach the rubber airseal on at this stage there will be a distinct "step" which of course is not right. Has anyone come across this situation before and what was the fix, does the cowl inlet need to be trimmed back ?
Thanks in anticpation
Martin
![cowlfit.jpg](/proxy.php?image=http%3A%2F%2Fimg528.imageshack.us%2Fimg528%2F7859%2Fcowlfit.jpg&hash=df09ce4576e42b51df45049e219b31a0)
Martin
