As the new Numatx squeezer produces constant force across the entire stroke, it appears that one has to use the supplied air pressure to control how much each rivet is squished.
Looking at a few sample builds with individuals choosing to attach the intensifier along with the foot pedal control to a sheet of plywood, i am also seeing everyone attach an air pressure regulator to the set up.
There is a large verity of regulators to chose from: digital, analogue, diaphragm, piston, etc.
I've seen specific examples of regulators that will not work listed on these forums (HF), however, i cannot find a single instance of someone specifically stating which brand they chose, and if it works well for them.
I'm considering the following: https://www.amazon.com/gp/product/B01LY2IO6C/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Thoughts on if it will work well with the Numatx squeezer?
