I guess I have different criteria and different experience.
My criteria would include light weight and small size, which the CP meets, as would the Sioux. People really like the Sioux, but the holes won't know if you used the CP.
Speed? Who cares? Supposedly higher speeds are better when drilling aluminum, but I only get holes drilled faster at high rpm's if I use more pressure against the drill. Then it breaks thru with higher pressure and you have less control. So I use a slower speed, probably only 1,500 rpm, but who knows? My drills are surplus, most of the data is unreadable and I don't know what speeds they are rated for. Most of the holes you will "drill" will be reamed, not drilled (I second the vote for a reamer) and you won't know the difference in drill speed when reaming. Just hit the trigger and the hole is done.
So, I say get any small, lightweight air drill at a price you are comfortable with & you'll be OK. And you can buy 2 or 3 CP's for the price of one Sioux and keep a #30 bit or reamer in one, a #40 in another.
