The air deflectors on the upper cowl are a bit of a mystery for me since they cannot be seen once the cowl is installed. I am trying to determine where to cut the front aluminum baffles on the flywheel side before I put the fabric on. Does anyone have a quick and easy (or not) way to do this properly. I have called Van's about it and they said not to trim the fiberglass deflectors but just install them full size and sand them to fit the contour of the cowling but noone has been able to give me any info on trimming the aluminum baffles around the flywheel opening. My concern is cutting too much and having to rivit a piece on to make it fit later. Any advice would be appreciated.
Also is everyone installing the air filter bypass on the bottom of the airbox? I did but I'm not crazy about it.
