Setting up my 60 gal Ingersoll rand air compressor, and trying to figure out what type filters/regulators I need and placement. The compressor will sit about 50 feet from my "shop", and temporarily just running a 50' air hose to a regulator that I keep at 90 psi (compressor is 175 psi) until I can install a more permanent line through the attic.
1. How many filters, and what kind do I need?
2. Should I put a regulator right off the tank and also keep the one further downstream where I will be working?
I will not be painting the airplane myself, but will be using to spray primer at some point.
