So my left aileron defects downward. Based on previous postings and a document Van?s had on their website, I groved the outboard left aileron bracket to lower the aileron height. After multiple adjustments downward toward 1/4 inch, the deflection geometry has remained the same (the outboard aileron height was lowered but no change to the deflection). The outboard side of the aileron sits well below the slip stream. My next move is to restore the aileron to the original position before the bracket holes where groved, then add a trim wedge under the left aileron to see if it at least deflect th aileron upward.
I am I missing something, or is it is what it is and just go with the wedge if it works.
