apkp777
At about 15 degrees of down travel, my aileron push rods contact the rear spar hole. On the up side they contact the spar hole prior to reaching the up stops and at about 30 degrees of travel. I have been racking my brain about this for hours. Anyone got any ideas.
Forget the lousy picture quality. I am no photographer. I have masking tape on the rod to prevent any damage to it. On the top of the picture you can see where one of the rivet heads has made contact with the spar before reaching the up stop.
The 421 bell cranks appear to be installed correctly. The 421R goes in the left wing and the 421L goes in the right. That seemed backwards but is what the drawing shows.
[/IMG]
