rleffler
I've been working on my aileron and flap rigging the past couple of days. I'm still not finished, but I thought I would solicit some opinions on the best methods to finish the rigging.
Here's my data:
Aileron Up Down
Max Travel 32 17
Min Travel 25 15
Right 29.7 17.3
Left 28.7 16.9
Flaps are up and flush with the bottom of the fuselage. Ailerons are flush with the flaps in the neutral position. There is about a .4 degree variance between the two flaps. I'm slightly over the limits on the right aileron at the moment. While the trailing edge of the left flap and aileron are flush, I still have the right aileron about 1/8" shorter than the flap trailing edge.
My question is how far to chase these specs down? Clearly have have to get them within the published specs, but what's the impact if they are within specs but may not be symmetrical? I'm guessing that the roll rate may be slightly different depending on the direction of turn.
On the trailing edge differences, I guess the best method is to disconnect the flap and see what angle do they match.
Any tips on getting these rigged a little closer together would be appreciated.
thanks,
bob
Here's my data:
Aileron Up Down
Max Travel 32 17
Min Travel 25 15
Right 29.7 17.3
Left 28.7 16.9
thanks,
bob
