The aileron pushrod as it goes through the hole in rear spar is touching one rivet and then then at full down position is chaffing against the inboard aileron bracket. I have checked parts positions and everything seems to be in the correct orientation and alignment. If anyone has seen this and has any suggestions I would appreciate it.
Thanks, Ivan
Thanks, Ivan
