Andy Hill
In response to an RV-8 question, I made a post [Link] that others seem to agree is a good summation.
The same process seems to be good for the RV-3B, but may be more informative since the instructions are silent on some aspects of it.
My suggested sequence:
Just do your best and hope the (small) errors balance out ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Fit Wings / Rear Spar attach to final drill
- Align Ailerons using tool v outboard rib holes. RV-3 note: This tool is not described, but basically, using a piece of wood and AN3 bolts into the tooling holes in the OB Rib aft portion, align these holes with the Aileron TE.
- "Lock" Ailerons using Bellcrank tool RV-3 note: This tool is not described, but make up a piece of AL with AN3 hole, onto each Bellcrank 2" (or 2.5") long (as stated in the drawings) from aileron pushrod against the spar surface
- Align Flaps to Ailerons
- Fit Fus/Flap Fairings to match Flaps RV-3 note: Easier to use RV-8 parts
- Fit Wingtips and attempt to align with Aileron/Flap.
- If Wingtip fitting not going too well, aim to align Outboard Tip of Wingtip with Aileron/Flap. Then "unzip" some TE of Wingtip, and use the fitting of the Tip Rib and some Resin back in TE to now align Inboard end. RV-3 note: This seems less of an issue than the larger RV-7/8 Wingtips.
- Some creative artistry is now required to bend up the Inboard Flap ends to match the fuselage somehow...
