jlfernan
It's a little hard to see in the photo, but I'm building a 9A QB. When I mounted my left aileron for the first time, I noticed that after tightening things up, the screw does not go thru the bearing square to the bracket. The larger washer nearly touches the bracket on one side. I put a 10L washer between the bearing and this washer and now have plenty of clearance. I did check that the washers were flat first. The bracket is about 1/32" out of square but the aileron movement is smooth. I just need assurance that this is fine.
![](/proxy.php?image=http%3A%2F%2Fimg217.imageshack.us%2Fimg217%2F551%2F20061010image0010bh7.th.jpg&hash=856643233653e60538add5c9c3e79f90)
