aileron attach brackets
AltonD
On the left aileron, the plans, dwg 13A, shows A-407-R. Is this a mistake or is -R the correct bracket? The holes do not line up. If I use the -L on the left aileron, the holes line up.
Help
AltonD
Thanks Roberta, that was my thinking.
Kevin, if you look at the insets, A-A, AND B-B, they are for the right aileron. that is the only thing I could figure out. Unless I am looking at it backwards.
