Fly4Funn
Member
I'm starting to attach flaps and ailerons and noticed that with the flap in the up position and the aileron aligned with the flap at the trailing edge, the top of the flap is about 1/8 to1/4 inch (haven't really measured it) lower than the flap at the front edge on top, and about the same below the flap on the bottom. As well as I can remember, the aileron hinge brackets were pre-drilled as were the end ribs so I don't think I could have messed that up. Anyone else see this and if so what did you do to fix the issue?
