I have a QB wing and am having trouble deciding which of two holes in Rib 912 is the froward tooling hole. One has a plastic bushing in it and the other is 3/16 in size. They are just 5/8 inches apart but could significantly alter the aileron and flap position> Two holes in line with each other in the vertical position just in front of the lightening hole nearest the main spar. One is 1 7/8 inch from the bottom edge and the other is 2 1/2 inches from the bottom edge. Which is the correct one?? ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
