wingnutzster
Member
I know this has been asked before, sort-of, but I am struggling to find an example of specifically the MGL SP-6B and SP-7 magnetometer and AHRS installations....I found what research suggested was a good location for the magnetometer (SP-6B) just under the keel, up in front of the F-707 bulkhead, I fabricated a 'tray' of sorts which can be pulled out for servicing - the unit is mounted on a rubber mat and the all attachment points are vibration dampened but where would be the best location for the AHRS (SP-7) unit?
It has to line up with the SP-6 on 3 axis and obviously has to avoid all vibration and heat/cold....I initially thought to mount it right next to the SP-6 on the same tray (there is adequate room for it) but after reading the notes and the forums it appears I am too far from the center of rotation?? It was suggested by Rainier that best theoretical location would be the center of the roll and pitch axis.
If someone can post a picture of their installation that would help a ton, lining it up with my mounted SP-6 might be a task though. :roll: :roll:
Also, without slamming my build quality (because I do my best) or scrutinizing every rivet in the region of the subject could you please comment on my servo installation - will this do? With some force the keel itself - to which the bracket is secured - can be pushed 15-20mm from left to right but there is no play back and forwards or twist.
http://www.avcom.co.za/phpBB3/download/file.php?id=157186&mode=view
