For those with a 175/375 in a tailwheel aircraft how did you calibrate the AHRS system. I tried it with the aircraft level (leveled in pitch and roll via the slider rails) and it gave weird results in the synthetic vision mode on the 760 and on Foreflight on the iPad. I also tried the "cage gyros" mode in smooth air level flight but that did not seem to set a persistent pitch and roll offset.
I am also not sure if the cage gyros mode actually adjusts the AHRS configuration settings or just sets a pitch and roll offset (same question for Foreflight on the iPad).
I just recalibrated with the -7 sitting in the normal ground position and the synthetic vision seemed to be somewhat correlated (showed level wings and about 9 deg pitch up).
Any input appreciated.
Figs
Figs
