cderk
Hey All -
I'm finally ready to start messing around with ProSeal. I'm working on putting the Aft Inboard Tank Rib Assembly together and I'm a little nervous.
First, this section says that "Assembly steps from this point on require that sealant be installed between mating parts". OK, got it. Everything needs ProSeal moving forward.
So I'm looking at Figure 2 on Page 18-5 and I see that I'm attaching T-1010 (Anti-Rotation Plate), Fuel Flange and 5 nutplates. Am I putting proseal on the nutplates? If so, where? Or am I wanting until I screw something into the nutplates and then seal everything up at that point. Same goes for the Fuel Flange. Am I waiting for screw something in there and then proseal around it?
Just having a little difficulty understanding the process here.
Thanks!
Thanks!
