IowaRV9Dreamer
I'm having trouble getting the F-779 tailcone skin and it's 2 bulkheads (F-711 and F-712) to align with the side fuselage skins.
With the stringers in place (but not drilled) I can get a good alignment of everything, but the F-779 holes don't align with the side skins holes. I can't put clecos in and pull it together because the stringers are in the way.
For fun, I pulled out the stringers (whoopee). Now I can get the tailcone clecoed to the side skins, but the bulkheads are now "too high" for the holes on the side skins.
I've spent a ton of time improving the shape of the tailcone skin - I think that's OK.
I've been working hard on the F-711 and F-712 bulkhead flanges - I may need to make some modifications there to "lower" the bulkheads down into the curve of the tailcone.
I know others have had problems there... is there a magic bullet? I think I really want everything to align perfectly without the stringers, so I can slip them in without changing anything. The problem is that the stringer holes also attach the tailcone skin...
Thanks in advance...
