yankee-flyer
Drilled the side skirt holes and enlarged all holes in the Plexiglass today. Thanks to all the info here, I used the hand drill and abrasive countersink and everything went perfectly (BIG sigh!). The canopy is on!! But the most aft top hole in each side skirt doesn't go through any part of the canopy frame-- just the skirt and plexiglass. Still use bolt and nut to hold the skirt to the plex? And on the right side the hole is too far aft-- the nut will hit the rear rollover bar. What have the rest of you done?
Thanks AGAIN! Wayne 120241/143WM
