CharlieWaffles
I am working through the engine install process and will eventually be using the AFS 5600 series (currently on order). I am wondering about the step where the plans have me run a line from the manifold pressure port to the firewall by using the Vans IE VMP Install Kit. It is using a VA-170 fitting through the firewall which appears to be the correct 1/4" size AFS needs. But I wanted to verify this setup will work with the AFS system as the Vans plan says other guages may need something differnt and the AFS instructions for the manifold pressure says "it is connected to the engine manifold pressure port with a 1/4" ID hose and hose clamp.
Since I dont have the EFIS system yet I can't actually examine the transducer. So would like to confirm this installation.
![Capture-6.jpg](/proxy.php?image=http%3A%2F%2Fi1079.photobucket.com%2Falbums%2Fw513%2Fcheapguy69%2FCapture-6.jpg&hash=9293f6a89518771105f05363c8297fb9)
