AFS 5600 and Apollo SL30
jdeas
Is anyone using their AFS-5600 to control an Apollo SL30? If so can you tell me your software version?
With my unit, the NAV side of the radio works as expected.
The COM side does not appear to react to commands from the EFIS however the EFIS does receive and display the COM status.
Both sides share a common serial line so wiring does not appear to be the issue.
I would upgrade the software to test but SL30 does not have an inexpensive software upgrade like the modern gear.
Apollo SL30 Nav v1.1, Com v2.1, DSP v1.1
