The button battery for memory and clock setting on my AFS unit has given up after 15 years of service.
I have checked with tech support to verify the existence - but not the location. They indicate they can probably replace the battery - but also probably don't have one in stock...leading to a long turnaround time.
Anyone out there had theirs apart to replace this battery? Can you tell me where it is located? Can you tell me what part number the battery carries - so I can try to get one.
Meanwhile, the clock synchronizes after it gets a signal from the GPS so it is not life threatening...just annoying from a data capture perspective.
Thanks!
Thanks!
