Phil
Can some of you post some photos of your purge valve with the cable control attached?
I was looking at mine closely today and the valve is clocked in a way that I have to push for cut-off and pull for rich. Exactly the opposite of what we want. Looking at my setup closely, I can't see any way to re-route the cable and re-clock the arm in a way where you pull-to-lean.
If you can post a pic of your setup, I'd appreciate it. I'm sure I'll have to make some modification to make it work correctly.
Phil
Phil
