Installing Aerosport Carpet today with a center console and have a question. There is a piece that fits in front of the rear seats and drapes over the tunnel. It has cutouts for the front seat belt attach points as well as the rear heater vents in side of tunnel.
My question is, do you cut that piece to fit around the center console? Or, is it supposed to fit under the console? It appears you have to cut around the console as the carpet thickness would be a VERY tight fit. I have to force the console down over the tunnel cover as it is, I can't imagine that it has enough give to also have carpet wedged underneath.
Before I start cutting, needed to reach out to others with this setup to see what they did.
