n981ms
I received my rudder trim and it certainly looks to be a quality unit. I did not receive any instructions. Overall it is fairly self explanatory and I have reviewed Aerosports website photo (http://www.aerosportproducts.com/ruddertrim.htm) but I still have a few questions.
1. Is there a particular angle to mount the control horns at?
2. The control horns have 3 holes. I think I remember reading somewhere that for the RV-10 the top hole is used. Is that correct?
3. Is the spring tension set such that at full rudder deflection there will still be slight tension on the spring? Specific tension or amount of spring stretch?
4. What tool is used to crimp the sleeves onto the wire?
Thanks in advance
Thanks in advance
