I also had the IO-360-M1 from Aerosport and was really happy with it. I believe I ordered the same F/W foreward kit as well. Here' what I found:
1) Baffle kit worked well, no major issues
2) I have the stock oil cooler as provided in the kit. We'll see how it performs.
3) Prop gov. installed without problems however, you'll have to change out the oil cooler supply line fitting. Dan C's website also mentions this.
4) For the RS-5 FI, the fuel supply line from mechanical pump to servo fit well.
5) I eventually replaced oil cooler supply line (added 45 deg fitting to clear prop gov), oil cooler return line (originally too long, neatened this up), fuel supply line from f/w to mechanical pump (original way too long), and manifold pressure line (again, way too long). Oil and fuel presssure lines seemed OK, but the oil line could be shortened by an inch or so.
6) Had to go through several hoses to position the fuel flow sensor between the servo and the spider.
7) Aerosport will ship with an alternator if you want, make sure you delete Van's.
Otherwise, the kit seemed to work well.
