Lynnb
I started looking at installing the Suntail today, realized I should order the cleveland mount to make this easier. So while I wait for the mount to get here I was thinking how do you ground the light Chassis as called out in the plans? I'm not talking about the ground for the light itself, I have the black ground wire running all the way back to the field of tabs at the panel. But in the instructions it calls for grounding the chasis of the light locally to protect from lightening, so wondering how others did this. Guess I should also mention I wasn't planning on installing the lower rudder fairing with nutplates, just rivets per plans.
Thanks in advance,
Lynn
Thanks in advance,
Lynn
