Hi Brian,
I am surprised that you chose to install a set of Pulsar EXP lights in the cutout of your RV-10.
The Pulsar NS90 is the light that we designed for that application, while the EXP is designed for mounting on the exterior tip of the wing.
The NS90 is shorter, and does not have the rear white position lights, which will be blocked on your EXPs in your installation.
The standard lighting package for RVs that have the lights installed in the wingtip notch is a pair of NS90s and a Suntail.
The Pulsar family of products includes:
Pulsar EXP (long body experimental with red or green/strobe/white)
Pulsar (long body TSO pending with red or green/strobe/white)
Pulsar NS90 (short body experimental RV specific with red or green/strobe)
Pulsar NS180 (short body TSO granted with red or green/strobe)
Pulsar NSP (short body TSO granted with red or green/strobe/white)
Note that short body means the same length as a Whelen A650, while long body means the same length as a Whelen A600.
Here is a thread that compares the footprint sizes:
http://www.vansairforce.com/community/showthread.php?t=74521&highlight=aeroleds+footprint
If you would like to exchange your EXPs for a set of NS90s, please contact
[email protected]
Best Regards,
Dean Wilkinson
CTO, AeroLEDS LLC
