AeroLED noise
Mona44
Member
Hello everyone,
Did our first engine runs today ahead of a planned first flight next week. One snag was low level noise with the Nav/Strobes on (AeroLED). I have an ES-00184 Noise Filter in hand but no wiring directions. I am not using the Van RV14 loom. Does it go in-line to the strobe or Nav 12v lines?
Regards,
Monica
I used the AeroLED nav/strobes in my wingtips with no noise in the audio system. I used shielded wire to the lights and grounded the shield at both ends. I also ran a dedicated ground from the lights to the firewall "forest of tabs" grounds on the rear of the firewall. I did not use the noise filter. I would check for grounding problems in both the lights and your headset plugs/system. The filter may work but it seems that ground loops / grounding issues are often the cause.
Looks like the ES-00184 is installed between the strobe power wire (Yellow) and gnd (airframe)
Attached schematic (OP-55)
I'm guessing you used the Van's wing wire kit. Don't.
Use a three #20 conductor shielded wire, like this: https://www.steinair.com/product/20-ga-3-conductor-shielded/
Conductors:
- Nav power
- Strobe power
- Strobe sync
- Shield is the common ground.
Ground the shield at your common firewall ground.
I take an extra step of adding a small aluminum backing plate inside the wingtip - so that the wingtip glass is sandwiched between the NAV/Strope and the aluminum backing plate. The backing plate need not be much bigger than the NAV/Strobe mounting bracket. Take the black ground lead from the NAV/Strobe, shorten so that after you attach a ring terminal it will fit under one of the bracket mounting screws. The three conductor shield also attaches via a ring terminal to this same screw.
This should eliminate all NAV/Strobe noise. Filter not required or desired.
Carl
I used the Vans wiring in the wing and it works fine with no noise so YMMV. The key to this setup is to not ground the light or the nav/strobe at the wingtip. Connect the nav/strobe ground at the light ground post, then carry that connection to the fuse at the wing root or on to the master ground point.
I grounded at the wing root on the fuse. No noise of any kind from the lights in any configuration.
There was also a generation with known problems, if yours are prior to 2018 AeroLed has been swapping them.
