AeroCraft Panel .DXF
jhutch
Member
I am working on a RV-10 panel upgrade for a friend. Anyone happen to have the dxf file for the circuit breaker panel?
Vertical Power
If he is upgrading, use that space for something else. Get yourself a Vertical Power Pro and ditch legacy circuit breakers.
The problem with the Vertical Power Pro concept is, are they going to be in business and support this product in thirty years? Keep in mind our RV-10's should last 50+ years ... Individual circuit breakers are easy to replace and inexpensive. If something goes wrong with VP-X, you are talking about few thousand dollars, and that is if it is available.
