hlangebro
I've been checking potential weight and balance scenarios. Granted my 7A is not flying yet and have not been weighed, however I think I am fairly close on the balance numbers.
Here is my question; it seems like if I reach 1600lbs, I am at the aft end, or outside of the aft end of the AEROBATIC envelope...Still within the Utility category envelope though.
So, for instance, would it be wise to do a spin outside of the AEROBATIC envelope, but still within the UTILITY envelope?
Just trying to figure out the limitations of the aircraft, and if it is prone to a flat spin condition outside the Aerobatic category, but still within the Utility envelope...
Mine seem to be a bit on the tailheavy side. I have a O-320, 160HP, ground adjustable Whirlwind prop with a 2.5" spacer....and I can only assume at this point that it is more aft than fwd, based upon my engine choice/weight and my preliminary calculations...
