In theory this should be an excelllent device because it tells one how much fuel is left in the tank as oposed to how much went through a flowmeter. With my Cherokee, I use a calibrated dipstick, so I always know how much is in the tanks before I take off. I plan to continue this practice in the RV-7. In the case of the flowmeter, although rare, there is no way to know that you developed a leak or are somehow venting overboard. Knowing how much you have left means exactly that.
I am interested in installing these optical low fuel sensors in my RV-7. This is a question for any listers who have installed the system.
1. What fuel level did you install the sensor at?
2. Where is the physical loction of the sensor? It seems to me that our tanks are likely to be virtually identical in shape/interior volume. I'd like to take advantage of someone else's prior effort and avoid reinventing the wheel. Please indicate if you took dihedral and angle of attack into consideration when you set up the system.
3. Does it work as expected and are you satisfied with your installation?
FWIW, I finally completed riveting the right wing and have the bottom left o/b skin to go. I would like to order the AE Fuel Guardian and receive the parts by the time I finish riveting the left wing.
Larry Tompkins
Larry Tompkins
