Advice on Landing Light(s)
Taking delivery soon on my Wing Kit and have included the LN Wing Tip LED kit for strobe/nav lights.
Now wondering about landing light and would lean toward the 'LL LED Kit A' that Van's offers, just for MFR uniformity with the wingtip and tail lights.
I don't expect heavy nighttime use, but want to be adequately equipped should the occasional need arise.
I'm building a taildragger.
What's the braintrust here say?
Is one Aero LED SunSpot LX (Par36, 1500W) in one wing enough, or do I need to consider one in each wing?
Also, is there any need for a "Taxi light"? Seems like that might be overkill...?
Thanks for any experience-based opinions.
I think you'll want a taxi light since you're building a taildragger. On the ground with the tail down the taxi light will be aligned with the runway or taxiway. The landing lights will be aligned with the runway with the tail up.
+1. Landing lights are not on the required equipment list for night flying, and, in fact, you should have no trouble landing at night on a runway with reasonable lighting. However, some taxiways, ramp areas, etc, may have poor or non-existent lighting. Given a choice of only one, I’d go for a taxi light over a landing light.
OK, thanks for the info guys. Now, any recommendations for taxi light mounting kits and/or configurations for a taildragger?
Can't seem to see anything in Van's or in AeroLED except references to bulbs.
Take a look at FlyLEDS - Paul makes a heckuva product and provides terrific service, even all the way from Australia.
Give Geoff at AeroSport Products a call to see if he taxi light will work on a RV-14. I haven’t spoken with him in awhile and don’t know what Rv-14 specific products he has these days.
Flyleds
Hi Randy
For your intended mission profile you could use two of our Combo lights, which were designed with tail draggers in mind. This way you get to have both landing and taxi lights on both wings so you can still see where you're going when the tail is on the ground.
Our The Original position and strobe light kit fits your wing tip light bays as well.
We also sell an RV-14 harness integration kit which allows for the Flyleds wing kit and one of our tail lights to easily plug into the Van's wing and empennage wiring harness.
Click the Flyleds logo to come for a visit! You'll see we have a bunch of other options and combinations as well.
I put in a Duckwork's kit on each wing when building, which came with PAR36 halogens. After getting it in the air, I found these halogens were really not all that bright and sucked quite a bit of power. I retrofitted with FlyLEDs "Combo Leading Edge Landing/Taxi light" kits in each wing. The bolt pattern match and heatsinks fit through the PAR36 hole after removal. I needed to trim a bit from the corners to fit them in through the lens hole, but other than that it was a piece of cake. Great product!
Randy,
I went with Vans standard offer. For taxi, I merely aimed one lite down, leaving the other in flight attitude.
That's what I like about this forum...an alternate solution is found, and better yet it even comes from an advertiser who supports the forum. Win-Win.
And to take it a step farther, FlyLEDs Seven Stars will light a runway into tomorrow. Highly recommend. No modification to leading edge needed on a 14 as the cutout is sufficient for installation.
Van's standard mounting kit works just fine.
And great service from Paul!
I will be ordering a QB wing kit soon. Planning Seven Stars in the leading edge. Not sure what I need to omit in the order and what to keep?( just order the Van's standard mounting kit?) Also, which Flyled kit do I need for the tips? (since ldg and taxi lights will be in the leading edge).
Jim
PS Sorry for the slight hijack
I have AeroLites and I’m very happy with them. They are very bright, and they make no noise - guaranteed, according to their manufacturer. I’ve found that to be true. I mounted them on Duck Works LE fixtures. I have them wired through a FlyLeds wig-wag module, and I am very visible, even in the daytime. The SS-T 2100 lm bulbs weren’t available when I got mine, and they may be worth the nominal extra cost (50% more lumens). Nothing wrong with mine though. I’m usually the brightest eye in the sky.
https://www.aero-lites.com/web-store
