This past July my RV-12 was painted with Sherwin Williams Sunfire PRO Urethane and coated with Sherwin Williams Sunfire PRO Urethane Clear Coat.
There are two things that I am looking for advice on:
First, any suggestions on how to remove the white dust that has collected in the center of the pulled rivets from the wet sanding the clear coat with rubbing compound? This is most noticeable in the areas that are colored rather than the white areas. Also, the rivets facing upward are more challenging to clean than the ones that are horizontally orientated.
Second, what is the best way to “wax” an RV-12 considering all of the protruding pulled rivets? What type of coating, wax, ceramic or something else? Which product? Application effort and how long does it last?
Many thanks.
Brett
Columbus Indiana, N4BH
Many thanks.
Brett
