It seems as though every plane I have flown with electric trim has had a failure of some kind and with no manual backup, you will be stuck flying your out of trim airplane until you can land and sort it out.
And the same goes for electronic "glass" panels. STICK with vacuum gauges...........'cause when the glass fails, you'll be completely lost!
I just had to say that..., since N941WR just went with a glass remodel.
Reading the above, it would seem that electric trim failure is eminent sooner or later, and that some poor soul will be pulling or pushing the stick with their last gasp of weakened muscles, just to keep the near doomed plane airborne. That is far from being realistic scenario.
In reality, electrim trim in a Vans airplane is a simple to install, and reliable piece of equipment. There have been some failures of earlier trim relay boxes.............which have been replaced with an upgraded model.
Even at that, you don't have to wrestle with the airplane.
I also installed electric aileron trim. It uses a servo & tab on the aileron, which is superior to the bias spring method (elec. or manual). Trim for both aileron & elevator is with a hat switch located on the stick. For landings, this allows me to keep my left hand on the stick, while right hand is on the throttle , while I can also flip the electric flap switch located next to the throttle. Manual trim has "slop", that's induced when the cable is reversed 180 degrees to the dial. Electric trim, with it's very short push rod has no slop. Cable "slop" has apparently caused no problems, but seems to bug a few aircraft inspectors. I prefer the "ridged" no slop electric method.
BTW--- I actually DO like "glass" panels too...
