I assume the ADSB receiver is located in the aft section of the tail (based on the wiring harness I installed that came with the tail kit). Any opinions on if this is a good location. I’m worried about moisture getting into this area.
I put my ADSB receiver behind the panel and its antenna is mounted under the baggage compartment. The antenna location in the tail, under the vertical stab. was for when ADSB and transponders were separate boxes - they are combined in newer avionics and, at least Garmin says to mount the antenna closer than at the tail. In that case, you won’t need the coax that goes all the way to the tail.
I'll admit a mistake...
The antenna location in the tail of the RV-14 in F-01479 is for a UAT device (978MHz).
If you are planning on a Garmin GTX 330ES, 23ES, 345(D), 45R, GNX 375, etc. or similar unit that combines Transponder + 1090ES, ADS-B/In & Out, you should use the location as drawn on page 26-11, Figure 1 - also on page 26-14, Figure 1, for the antenna.
The dB loss/attenuation incurred by RG-400 at 1090MHz is about 18dB/100ft (varies a little with manufacturer...) GTX 330 has a limit of 1.5dB max loss and GTX 345 has a limit of 2dB max loss which means you are limited to < ~9Ft of RG-400.
Now I get to patch some holes and remove a chunk of RG-400, c'est la vie...
Thanks, now I need to figure out how to cover the hole where the antenna was supposed to mount... will need to hit up my multiple RV build neighbor for help....
I'm working on this section right now. I'll be installing a Garmin GNX-375 so it appears I don't need this furthest aft antenna location. I've final drilled the #12 holes in F-01479 but I didn't final drill the larger 9/16" hole. What did you use to patch the holes?
This is the area I'm referring to:
Pictures Pictures Pictures...
It's overkill...
+1 on Brian's comment; shorter is better for the transponder coax run, as long as you have the minimum required length (3 ft for the GTX-45R).The dB loss/attenuation incurred by RG-400 at 1090MHz is about 18dB/100ft (varies a little with manufacturer...) GTX 330 has a limit of 1.5dB max loss and GTX 345 has a limit of 2dB max loss which means you are limited to < ~9Ft of RG-400.
It's overkill...
Thats a great solution to cover the middle 9/16" hole. But, what would you do if the middle hole hadn't been final drilled yet and was still #30? I could put an LP-4 in the #30 hole but what about the #12 holes? Are there pulled rivets that will fit in those holes? I've looked but so far haven't been able to figure out what size rivets those would be. Sorry, new builder here...
