Got my 14 mostly rigged .. everything went well but ran into an issue with the rudder.
I have 33 degrees deflection without the cables, both directions. The called for min was 30, max 35.
With the cables attached I'm getting probably 25-27 degrees max.
I have the pedals installed in the middle position and the cables attached on the far aft hole.
Is the 30/35 degree min/max supposed to be with the cables attached? If so, I'm at a loss how to adjust it from here.
Any advice appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
