Tell me about adjusting the maximum RPM setting for a Hartzell CS prop.
Today I tied the airplane, pulled the spinner, and made a few full throttle runs, adjusting the low pitch stop screw each time as indicated in the prop manual. Took about two full turns to get the 2650-2700 RPM range static at WOT.
First takoff was fine, 2710 RPM. However, later when doing T&G's I looked down and saw 2800. Only idea I have is warmer oil, 185F vs 100-120F on the first takeoff with Phillips 20-50.
So what gives? Am I missing something?
