Rick6a
I have a question about the mechanical stops on the two identical servos that came with my ADI Pilot II. Page 3 of the ADI Pilot I & II Autopilot Installation Manual states "The servo arm must not rotate even near to the point called OVER CENTER, the point at which the primary aircraft control would lock up"......and........ "To protect against this, mechanical stops are supplied with the servos. These stops are drilled so that they can be mounted at different angles as required (18 degree intervals)."
Where are the drilled stops that can be mounted at different angles? What do they look like? I can find nothing in the two included hardware bags that might be used as stops, nor do I see anything on the included drawings (the same ones that are downloadable from TruTrak) that would account for the stops. What am I missing?
![autopilot00210hi6.jpg](/proxy.php?image=http%3A%2F%2Fimg102.imageshack.us%2Fimg102%2F3659%2Fautopilot00210hi6.jpg&hash=48ecf16bed54dd692b94c7adf214272c)
