Adding the Rudder Trim Tab
n74846
I am flying a legacy 12 (2014) that I did not build. I am adding the optional trim tab kit to a newly built rudder to replace the original rudder(a whole other story). I notice a pre-bent angle in the tab. Is this the recommended start point or should the tab be straightened and deflected as needed later? Thanks!
I installed the trim tab as received from the factory and the angle was dead-on perfect for torque compensation. I have not had to adjust it since installation.
Agree that Van's trim tab angle is correct for high-speed level cruise. You will need a couple of pounds of force on right rudder peddle in climb and lightly rest your foot on left rudder peddle in glide to keep ball centered.
