Piper J3
Several folks have added a switch to control the RV-12 electric fuel pump which is set to run continuously as designed by Van?s Aircraft. I?ve been thinking about incorporating this change.
A couple of questions? I?m thinking of using the unused Auto-Pilot switch. I would need to re-label the switch and it?s corresponding fuse. Is this a good idea or should I just add a new switch in-line with existing pump wiring? If I add a new switch where do I place it? I?m thinking I would install it in place of the AP disconnect switch next to the throttle.
Thanks in advance?
Thanks in advance?
