Grove master cylinders
I did my RV-6A a couple of years ago, and I used the Grove master cylinders. I highly recommend them because they are adjustable. You can adjust the length of rod, which means you can set the brake pedal angle perfectly, and easily.
If you have ever flown an RV with the pedals too vertical, you will know what I mean.
