I'm trying to figure out why the oil pressure gage is indicating 83 psi even with the engine not running. If I unplug the wire from the sensor, it will go to "0".
I've confirmed the wiring from the transducer/sender is correct to the GEA 24. the sender is the Kavlico 4055-150.
I've set the red line in the config. mode. Is there a calibration procedure to set it at zero?
I did find a couple of mistakes with some other things by accident, while searching the oil press. issue like the tach pick-up. It was in the wrong hole of the magneto.
The oil pressure is the only thing that has me concerned at this point. Any suggestions would be greatly appreciated.
