RV7ADRIVER
I'm New Here
I am trying to find a copy of the ACS Ignition Switch Service Bulletin SB92-01.
I've had no luck finding the text of the Bulletin with a search engine look up.
ACS Ignition Switch Part No. A-510-2
I believe that is the Ignition Switch included in Van's wiring kit.
My switch is newer than 1992. The SB probably does not apply but I want to know for sure. Do any of you know how to tell if that bulletin applies to a given switch? [Color mark, S/N range, etc.] Thanks.
