hiddenhearth
Member
This weekends RV6 project is to rebuild all 4 master cylinders (2 Matco on right side and 2 Clevland on left side) and install ACS 600 brake reservoirs then bleed the system. Rebuilding of the cylinders is required due to air getting in lines. See previous post. Any suggestions or pictures of the reservoir installation would be greatly appreciated. Not sure how two reservoirs will feed four master cylinders? I am sure I will figure it out if I don't go bald first! ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
